Is there a way to load "Predefines Unique Values"
78
Friday
SanchezNuñez
Good morning,
Is there a way to load "Predefines Unique Values". I am currently entering them manually.
DanielFox1
Hi @SanchezNuñez
Can you be more specific on the widget you are trying to use?
I have included a link to another community post which you might find helpful
Solved: Query widget - unique values - Esri Community
SanchezNuñez
Sure @DanielFox1 ,
in a Select, Query  or Filter widget when configuring the selection  with the button SQL Expression,  it opens a window called "SQL Expression Builder", then there is a way to Predefine Unique Values for a field.  I have to enter them manually. I am looking for a way to upload them, because I use this same search values in other widgets.
