fontsUrl configuration
144
Tuesday
MatejKutik
New Contributor III
Hello,
I encountered an issue when rendering FeatureLayer symbology. I found out that the reason is an invalid font URL. I could fix that by developing custom widget that would change esriConfig.fontsUrl.
Is there a way how to change fontsUrl without developing custom widget?
Thanks, Matěj
JeffreyThompson2
MVP Regular Contributor
JeffreyThompson2
Chances are the error you are seeing is because the font you are using is not one of the fonts hosted by ESRI. The best solution would probably be switching your symbology to one of the supported fonts. https://developers.arcgis.com/javascript/latest/labeling/#non-mapimagelayer-fonts
GIS Developer
City of Arlington, Texas
MatejKutik
New Contributor III
Thanks for answer Jeffrey.
That is not the true reason, though. The true reason is that my environment is disconnected from internet. Therefore I`m not able to reach https://static.arcgis.com/.
I`m pretty sure that all I need to do is set the fontsUrl.
JeffreyThompson2
https://developers.arcgis.com/javascript/latest/labeling/#custom-fonts-and-disconnected-environments
In that case, you will need a custom widget.
GIS Developer
