Feature Info widget is showing all the attributes in the popup window as blank when we have a direct URL in the popup
59
Wednesday
AndrewWallick
Occasional Contributor II
We're running into an issue where the Feature Info widget is showing all the attributes in the popup window as blank when we have a direct URL in the popup.
1. I've reproduced it with two separate Feature Info widgets with different layers
2. It doesn't happen when the exact same URL is put in as a hyperlink with alternate text
3. It somehow happens (attributes are blank) when the URL is put in as a hyperlink with the same URL as the text (see third screenshot below).
4. This doesn't happen in the web map popup.
5. It does not happen with the base URL for the experience builder, or with "https://www.google.com/". But it's reproducible for us when the URL for the exp builder app includes a selected feature.
6. It happens also when the URL is a different exp builder app (as long as there's a selected feature)
We have a workaround now, so I don't need to make a full support ticket. But this is a weird bug so wanted to let the team at Esri know.
