Failed to load map
84
08-12-2022 08:59 AM
BrettLawson1
Viewing a Experience Builder Developer Edition with a custom widget in local development environment every thing work correctly.  When it is deployed to an IIS website a "Failed to create map" text failed and there are several errors in the console.  The portal info is configure correctly in the config file.  Could it be something to do with authentication or something else?  The Web map is shared as public.
index.js:2 No portal info.(anonymous) @ index.js:2
index.js:2 Load module error. TypeError: window.require is not a function
at (index):296:12
at new Promise (<anonymous>)
at SystemJS.constructor.instantiate ((index):295:11)
at init.js:1:27896
22(index):296 Uncaught (in promise) TypeError: window.require is not a function
at (index):296:12
at init.js:1:27896
2index.js:2 Load module error. TypeError: window.require is not a function
at (index):296:12
at init.js:1:27896
See attachment.
Grant-S-Carroll
I have experienced something similar, it was solved by ensuring that the dependancy section of the manifest for the custom widget was filled out.
Grant-S-Carroll
