Experience Builder App issue - Data Action to select records in a table
233
5
02-22-2024 04:44 PM
gis_KIWI4
Hi Team,
I have run into an issue that I need help with.
I have the utility network trace widget.
Idea is that UN widget selects records in feature layer -> which then selects the records in a standalone table.
I have set up the data action in Map
And this works when I select a record manually.
This DOES NOT work when I run the trace UN Trace widget
It selects the records in the feature layer but nothing in the standalone table.
AlixVezina
Thank you @gis_KIWI4 , I looked into the BUG report.
Message actions are not supported for the Utility Network Trace widget as of Enterprise 11.1 or 11.2. You will notice there aren't any Actions that can be configured from this widget.
Message actions are a widget-to-widget configuration and must be configured in the Utility Network Trace widget to observe the expected behavior you have described. In other words, since the "records selection change" trigger is being performed by the Utility Network Trace widget when you run a trace, the Utility Network Trace widget is where the whole action needs to be configured.
Message actions will be available for the Utility Network Trace widget as of 11.3 (and are available right now in the ArcGIS Online version of Experience Builder). See this blog for hybrid setup: Configure an Application to Trace a Utility Network (esri.com) (see step 3)
AlixVezina
HI @gis_KIWI4 , please could you describe how your message actions were configured? Between which widgets and which actions?
gis_KIWI4
Hi Alix,
Apologies for the delayed response.
I worked with ESRI NZ distributors (Eagle), they have logged a bug for this.
BUG-000166323 - When running Utility Tracing - actions are not triggered to the Table widget.
AlixVezina
gis_KIWI4
Thanks @AlixVezina. I look forward to 11.3
When can we expect 11.3 to come out?
We are on 11.1 and support for subtype group layers is quite limited on this version.
AlixVezina
Right now, 11.3 is planned for May 2024.
