EB 2 Web Maps/2 Edit Widgets....2nd Edit Widget does not hold configuration
172
12-12-2024 04:57 PM
kmsmikrud
We have an EB that is for editing data. To make it easier for folks to use we essentially have 2 duplicate AGOL web maps but saved with different names. In one of the maps, a base layer polygon is turned on and in the other web map another base layer polygon is turned on.
The idea is for easier viewing in case people don't know how to go in and turn on/off map layers. I noticed today that the one edit widget looks pretty good and for mode is selected to 'Interact with a Map widget' and I have one of the maps selected and below shows the map layers within the web map to enable for editing.
However when I go to the second edit widget which is another section view, this one also has the mode 'Interact with a Map widget' selected along with the second web map, but no layers show to configure. I have been able to switch to the other web map and then switch back to the second web map and then the layers in the second web map will show as options to configure editing.  I save and publish and get the green light, but when I go back to the second edit widget, no layers are shown as configured for editing or even show within the web map setting. What is going on?
Shouldn't this be possible to achieve with two separate web maps and two edit widgets? It is the same hosted feature layers being configured for editing so maybe that is too much for the EB?
Thanks in advance. This EB is not going that well with already an existing tech support case regarding editing related records and also the group filter, both of which the tech has been able to replicate and states software limitations, enhancements....sigh.
Kathy
Ke_Xu
by Esri Contributor
Hi @kmsmikrud,
I couldn't reproduce this issue with the app https://experience.arcgis.com/builder/?id=b116de06119f40599a6dd7db57ee10cb&views=page.
Could you share your sample app with me so I can take a look?
What are the problems encountered when using Group filter?
Ke
kmsmikrud
Hi @Ke_Xu ,
Thanks for testing! I'm not able to view the link you shared. Would it matter at all if the sections are within a sidebar within the EB. Also for your testing does the editing involve the same hosted feature layer service?
In the screenshots below the first one shows the edit widget and interaction with the first map. The second edit widget despite selecting to interact with the map it doesn't provide an option to select map layers. I have been able to switch to the other map, layers immediately show and then switch back to the second map and layers to edit will be an option. I have saved settings and then go back to view the edit widget configuration and it looks like the second screenshot below in the layers have disappeared.
EB_EditWidget1_Map1_showsMapLayers.jpgEB_EditWidget2_Map2_UnableToSelectMapLayers.jpg
Group Filter, works for one SQL statement, but does not honor the 'AND' when multiple statements are added within the Group Filter. Also it will not zoom to filtered when multiple statements added.
Here is the other post.
The EB we have isn't publicly shared but I could add you to the organization group where it is shared.
Kathy
