Can't able to select feature after webmap change.
207
a month ago
MohammedHilal_K
New Contributor III
Hello All.
I facing an issue with selection of feature after changing the webMap. below is my code to change the webMap.
jimuMapView.view.map=newWebMap.
I'm trying to select the feature sing selection tool also selectFeatureByGraphic method as well. But none is working. But in default map, it working perfectly. I tried to create new jimulayerview with new webmaps layers, but that also couldn't help me.
Any help will be appreciated. Let me know if any further info required.
Thanks & Regards,
Mohammed Hila K
GIS Developer
MohammedHilal_K
New Contributor III
Hi @akbarhim
Can u elaborate little bit? Actually i have developed a widget to switch the map. switching the map is working perfectly, but after that selection is not happening. I suspect that the issue with datasource, it is taking the default datasource as map widget already has.
Can you please give some comment in this if possible.
thanks & regards,
Mohammed Hilal K
