A patch is available here for the developer edition 1.8. It addresses an issue that a feature layer from a map service does not respond to the feature filtering or selection. For example, the selected feature on the List widget does not get highlighted on the map, or the Filter widget can no longer filter the data. As this is a regression issue, we would strongly recommend installing the patch if you are using the latest version 1.8 of developer edition.
Here are the steps to install the patch:
Let's know if you run into any problems. Thank you.
