When publishing a service on servers running on arcgis 10.8, the layers names on my wms service have random numbers at the end, when i publish the same service with taking off the special characters and the spaces from the layers names on my mxd, everything is fine.
Thing is, i want my layers with these characters but without the random numbers at the end.
I didn't have this problem with 10.3.1
Thank you !
I have seen similar behavior when publishing or overwriting services using a cache. Could your problem be related to caching?
Hi ! Thanks for the answer, actually, I tried publishing a new service with a new layer with a name that has special characters. So no overwriting and I still had the same problem, problem that I didn't have with 10.3...
