Publish referenced building scene layer with relationship (not hosted)
320
5
11-21-2023 01:06 AM
mmarkovic
I'm trying to publish on Enterprise a Building scene layer as referenced. Some of its multipatchs contains relationships on a table.
When publishing it in a hosted Web Scene from ArcGIS Pro, the associated feature layer contains the relationships.
Unfortunately, when I try to publish it as a referenced Web Scene Layer, the associated feature layer doesn't contains the relationship. Is there any way to do this ?
MichaelLau
When publishing your building scene layer by reference you can maintain your relationship class set in Pro.  Here is a Learn topic on the subject:
https://learn.arcgis.com/en/projects/connect-a-3d-digital-model-to-additional-table-data/
Can you try the steps found in the topic and let us know if it still doesn't work for you?
mmarkovic
The steps in the topic show how to share the building scene into a web Scene. As far as I know, using this way will share the Building scene layer and the associated feature layer as hosted and not referenced.
It is working for the relationship but it is not what I'm trying to do. I need the associated feature layer to be referenced AND keep the relationship to the table, as configured in the SDE.
DA_BIM-GIS
Hello @mmarkovic
Yes, you can do what you are trying to do,  but you will need enterprise 10.9 or newer to accomplished the workflow.
We are working on a learn lesson specific on this topic which will be out early next year.
David
AzizTejan-Jalloh
Hi ...I look foward to seeing a best practises workflow that covers in detail publishing a webscene or scene layer that contain feature layers as referenced data and not hosted on the Portal datastore. It would be ideal because the feature layer should update automatically when there are any changes in the scene in this scenario. I am currently testing it out Enterprise 11.1. Do you have a more exact timeline for early next year?
Thanks, Aziz
mmarkovic
@DA_BIM-GIS I'm working on Enterprise 11.0. Can I have any advice to perform this since I will need to do it before next year ?
