Is it possible to add a time slider in Map Viewer Classic on Enterprise?
82
12-06-2023 04:01 AM
EmilyGoldsmith
New Contributor III
Hi all.
On our ArcGIS Enterprise portal, we have a feature service which has a time slider, and I want to add a time slider to another feature service which has esriFieldTypeDate data.
However, I can't seem to find any options to have it set up. It seems to be possible to configure in the following ways, though I was unable to find any options to set it up via the Map Viewer Classic itself on our Enterprise portal:
1)  On Enterprise via the Map Viewer:
https://enterprise.arcgis.com/en/portal/latest/use/configure-time-mv.htm
2) On ArcGIS Online via Map Viewer Classic:
https://doc.arcgis.com/en/arcgis-online/reference/configure-time.htm
I assume that the feature layer already had a time slider set up in ArcGIS Pro prior to sharing to Enterprise.
Any help and guidance on this would be much appreciated.
