HA Datastore with Relational & Tilecache, Primary - File not found nulltec\arcgis-data-store-config.json, Standby Validation Fails.
372
01-28-2023 02:02 PM
Taladi
New Contributor III
HA Datastore (Relational & TileCache) 10.8.1
DataStore01.test.com - Standby (DS01), Standby Validation Fails
DataStore02.test.com - Primary (DS02), Able to publish Hosted Feature Layer
Primary Datastore Log:
ArcGIS Data Store configurations store is not configured correctly, or a bad configuration is being used. File not found 'nulltec\arcgis-data-store-config.json'
Standby DataStore Validation:
https://datastore01.test.com:2443/arcgis/datastoreadmin/machines/datastore01.test.com/validate returned an error. The requested resource could not be found in the system. Please check the parameters and try again.
Any suggestions on this.
Thanks in advance.
