Give access to the Hosted feature service using Token access
450
8
02-21-2024 02:34 AM
AravinthkumarBalasubramanian
Hello All,
I have a Hosted feature service in the ArcGIS Enterprise, one of the client wanted to access the feature service using Rest services, so I have shared the feature service URL https://portal.de/server/rest/services/Hosted/point/FeatureServer
But when they wanted to use the layer in their system, it asks for a Token. So I have done some search and found this https://enterprise.arcgis.com/zh-cn/server/latest/administer/linux/enable-token-acquisition-through-...
And I have enabled the token acquisiton, in the Server admin, But I don't understand this https://developers.arcgis.com/rest/users-groups-and-items/generate-token.htm
To generate a token and link to the feature service, as I am very new to this some detailed explanation will be very helpful. Thank you.
HenryLindemann
Hi @AravinthkumarBalasubramanian, the token is a security mechanism that allows you to log into a service via an application, it is usually has a short life e.g. 2 hrs.' then you need a new token, if your client has a custom webpage, he needs to generate a token and attach it to the service. The token you have in the above code will not work because it is for use in portal, please see this sample on how to connect the service using java script you just need to Registe an Api key, instead of the token, but the tutorial will show you how to do that.
Add a feature layer | Overview | ArcGIS Maps SDK for JavaScript 4.28 | ArcGIS Developers
Regards
Henry
HenryLindemann
Hi @AravinthkumarBalasubramanian, so it does depend on your workflow, the below code is how you do it in python, but if your client has ArcGIS Enterprise then, you can just setup a secured service,
Under content new item
all that you are trying to build is https://portal.de/server/rest/services/Hosted/point/FeatureServer/{layerid}?token={token}
import requests
import json
import logging
def get_token_portal(portal_admin_url, portal_username, portal_password, referer):
url = f"{portal_admin_url}/sharing/rest/generateToken"
payload = { 'f': 'json',
'username': portal_username,
'password': portal_password,
'client': 'referer',
'referer': referer,
'expiration': '100'}
headers = {
'content-type': "application/x-www-form-urlencoded",
'accept': "application/json",
'cache-control': "no-cache",
response = requests.request("POST", url, data=payload, headers=headers, verify=False)
return json.loads(response.text)['token']
def query_rest(url, token, other_parameters=None, type="POST"):
"""url Root URL with webadaptor"""
url = f"{url}"
payload = {
'f': 'json',
'token': token
headers = {
if other_parameters is None:
response = requests.request(type, url, data=payload, headers=headers, verify=False)
else:
response = requests.request(type, url, params=other_parameters, data=payload, headers=headers, verify=False)
if response.text == "":
return None
if __name__ == "__main__":
portal_admin_url = 'https://e1091.esri-southafrica.com/portal'
username = 'portaladmin'
password = 'password'
server_url = "https://e1091.esri-southafrica.com/server/rest"
token_portal = get_token_portal(portal_admin_url, username, password, server_url)
req_export_backup = f"{server_url}/services/Hosted/service_8f8eccce65394272b49be5fb6f2e9087/FeatureServer/0"
response_version = query_rest(req_export_backup, token_portal, type="POST")
print(f"Result: {response_version}")
Hi @HenryLindemann
Thank you for the clear explanation, Yes, my client has ESRI Enterprise access, so should I create  a URL in the "New Item"  ? Kindly can you elaborate on that. Thank you.:-)
HenryLindemann
Hi @AravinthkumarBalasubramanian , yes under new item select web, you should see this page,
then select store credentials this is so that your client does not log in every time he opens the service, you log in with a user account on your system that has access to the service.
then just save
Hi @HenryLindemann
But this just creates another feature layer with the same data in it, but how do I share it like this  https://portal.de/server/rest/services/Hosted/point/FeatureServer/{layerid}?token={token}  I don't see the feature service in the ArcGIS rest service Directory.
HenryLindemann
@AravinthkumarBalasubramanian , can you give me the scenario of how you want to use the data?
The service will not display in the rest because it is coming from your server but you will be able to query it and use it in portal for ArcGIS.
Regards
Henry
@HenryLindemann, Sure, we are hosting the feature service in the ArcGIS Enterprsise, our client wants to integrate the hosted feature service in their system, its a web based system, so they have asked for the Rest service,
so we have sent the https://portal.de/server/rest/services/Hosted/point/FeatureServer service. But they tried to use the service and integrate in the system they get an error "Token required".
They have access to our enterprise system using credentials. The question is how do I create a token and attach to the Feature service so that they can access the service and integrate in their system.
We have Server Administrator for creating tokens, but I am not sure how this workflow goes.
So far I have used this script and generated a token and added to the Feature service like this example,
https://portal.de/server/rest/services/Hosted/point/FeatureServer?token=affcx78d4c5xfc
But if I open the url it refreshs automatically multiple times. So How do I share the Hosted feature service with the token to the Client, kindly help me to understand the concept.
from arcgis.gis import GIS
parameters ={
    "PortalURL": "",
    "PortalUserName": "",
    "PortalPassword": ""
for keys, values in parameters.items():
    url = parameters['PortalURL']
    username = parameters['PortalUserName']
    password = parameters['PortalPassword']
gis = GIS(url, username, password)
token = gis._con.token
print(f"Your ArcGIS token is: {token}")
HenryLindemann
Regards
Henry
