Feature with related table
540
09-19-2021 01:11 AM
MohammedElsayed
New Contributor III
I have 2 feature classes that are related to the same table (i.e. feature class1, feature class 2 and table1), when I publish the first one with the table as a web layer to the portal (enterprise portal) it went ok but when I published the second one with the same table it gives an error, however when I changed the table name it also gives the same error. but when I published the tow feature classes together (as one web layer) with the table also it went ok.
my question is : is there an way to publish the 2 feature classes separately with the same related table?
IhabHassan
HI @MohammedElsayed
can you share the error message?
Regards
Ihab
MohammedElsayed
New Contributor III
I updated the ArcPro version and it is ok now the problem solved. may be it was a bug.
Thanks.
