Datastore CLI tools: File not found 'nulletc/arcgis-data-store-config.json'
506
01-26-2023 04:17 PM
sparks11
I'm trying to use the changeloglocation.sh command line tool on a Linux instance running ArcGIS Datastore.
When I run it I get the following error:
sh changeloglocation.sh /var/log/arcgis/datastore/
Error encountered: ArcGIS Data Store configuration store is not configured correctly, or a bad configuration is being used.File not found 'nulletc/arcgis-data-store-config.json'.
Does anyone know how I can set the value currently set to null to the path to etc/arcgis-data-store-config.json ?
I was hoping there would be a switch to override the config location as an additional argument but that does not seem to be the case. I also tried "source arcenv" before running my command in hopes that would set the missing variable but it did not.
Any assistance or solutions are appreciated.
