Create Drive-Time Areas Measures dropdown in 11.0
36
Thursday
RobStauder
Any thoughts about what's going on here?
ArcGIS Enterprise 11.0, Utility services pointing to ArcGIS Online
  1. Open map viewer classic
  2. Add a point through either map notes or a feature layer
  3. Analysis > Proximity > Create Drive Time Areas
    1. Most of the time, the Measure dropdown does not populate. It looks like this:RobStauder_0-1678992241403.png
  4. If I open dev tools, I see a few errors on the console. Like this -
    https://foo.thing.com/arcgis/sharing/servers/ff44a2ea21a34a4ba37934010a2f67ed/rest/services/World/Utilities/GPServer/GetToolInfo/execute?f=json&toolName=GenerateServiceAreas&serviceName=asyncServiceArea&token=…. with these errors - Failed to load resource: the server responded with a status of 400 (Bad Request) and[USO] Button detection aborting due to timeout.
  5. However, if I fiddle with the widget, perhaps close it and reopen it a few times, the measure dropdown will work!
  6. However, when I run the tool, sometimes it works, sometimes it fails with You do not have permissions to access the utility routingUtilities. Create Drive Time Areas failed.
Am I missing a service timeout setting somewhere? What could be happening?
Thanks!
Rob
