ArcGIS Data Store encountered too many problems. Failover may be invoked if standby is configured
922
09-28-2022 06:04 PM
DebendraBiswas1
New Contributor III
Hello All,
We have noticed message "ArcGIS Data Store encountered too many problems. Failover may be invoked if standby is configured." in ArcGIS Datastore logs.
It also says that Data store machine has failed.
There was no issue observed by the customer at the front end, but they want to know what might have triggered this error.
Environment Details:
ArcGIS Enterprise 10.9 single machine deployment
Windows Server 2019 Datacenter
4 Cores, 32 GB RAM
Cheers
DZB
Tags (1)
JonEmch
@DebendraBiswas1 Hey there, thank you for posting!
   Thank you for posting the environmental resources. When you have a moment, could you describe the overall system resource usage on this system at idle and at load.
   In my research I've seen that this error can come about from a system that is running low on resources (RAM or CPU) under load. And while this may not cause access issues, it tends to throw this error.
Keep on keeping on!
