Web Editor does not open
170
5
4 weeks ago
JohnGoat
Hi everbody,
I am using ArcGIS Enterprise 11.3, the web editor does not open, I could not find a source about the reason. he page does not respond, it remains a white page.
@CraigGillgrass
[modal] component is deprecated and will be removed in v4. Use "dialog" instead.
CraigGillgrass
@JohnGoat Have you ever been able to open the Web Editor since it was installed? Or did this just start to happen?
The warnings you see in the console are not the issue.
JohnGoat
After installation I ran the application and did not experience any problems. It just updated the Google Chrome version.
CraigGillgrass
thanks @JohnGoat What version of Google Chrome did you update to?  Can you open Web Editor in another browser, such as Edge or Firefox?
JohnGoat
Chrome version is 131.0.6778.265 - Edge 132.0.2957.115 - Firefox 134.0.1 (64-bit)
I tried with Edge and Firefox but still couldn't log in. stuck on the white page
CraigGillgrass
@JohnGoat if this is an issue with other browsers, that seems to indicate it may not be a browser issue. I'd see if the portal can be be restarted and see if anything has changed on the server/portal.
You could also provide the network traffic when you try to connect - that might point to an issue.
Craig
