Publish routing services advanced properties
179
02-15-2024 12:54 AM
HannesGrothkopf
New Contributor III
Hello everyone,
when publishing routing services from a network dataset, it is possible to define advanced properties using the publishroutingservices.json file. This procedure is available both when publishing via the command line utility and the portal web interface (since AGE 11). The example file from the ArcGIS Server installation directory contains a large number of serviceProperties, whereas the documentation states that only "certain" properties can be customized.
Which properties are these exactly?
For example, we were not able to customize the serviceName of the services. If the property is set in a customized version of the publishroutingservices.json file and passed when publishing, the property is ignored.
https://enterprise.arcgis.com/en/server/latest/publish-services/windows/publish-routing-services.htm
https://enterprise.arcgis.com/en/portal/latest/administer/windows/configure-routing-services.htm#ESR...
https://enterprise.arcgis.com/en/server/latest/develop/windows/publishing-routing-services.htm#GUID-...
Kind regards,
Hannes
