Portal Logs Errors
312
11-21-2023 07:08 AM
vijaybadugu
Occasional Contributor II
Randomly I checked the error logs of arcgis portal, I found an error saying "
The portal has been initialized and configured but is not accessible. The internal portal database does not appear to be running or accepting connections. Restart the portal machine or machines and if the problem persists, contact Esri technical support (U.S.) or your distributor (customers outside the U.S.).
Do I need to do anything from our side ?
DanielBrumm1
Did you recently reboot your host machine? I get those after a reboot. As long as the Portal is working you should be fine.
Daniel Brumm
GIS Nerd
vijaybadugu
Yes. yesterday I did
DanielBrumm1
In my experience I  "think" those message are simply system checks that fail because the portal is restarting.  I have never had an issue with them as long as the portal starts successfully and the message stop showing up in the logs. Its a very big problem if all you see in your logs is that message and your portal is not working.
Daniel Brumm
GIS Nerd
