oAuth connection from Make (Integromat) to ArcGIS Enterprise Portal keeps requiring reauthorization
100
08-17-2022 10:39 AM
AndrewBowne
Occasional Contributor III
I have created an automation using Make (Integromat) that connects to my ArcGIS Enterprise sever using oAuth.  The problem that I am finding is that every few weeks I have to reauthorize the connection.  This proves to be problematic as the intent is for this automation to be... automatic!
I built my automation following the following Field Maps blog:
https://www.esri.com/arcgis-blog/products/field-maps/field-mobility/use-webhooks-to-automate-workflo...
Is there a reason I would have to keep reauthorizing?  Or, is there a way I should have it set up so that this doesn't keep happening?
