I am having an issue with a map service drawing in portal. The layers contained in the map service do not display, not even partially, and there is no error message. If I republish the service from ArcPro then it works just fine for a bit. It seems that it does not draw after a day or so has passed (after I log into portal for the day). The data set is not very large; the largest layer contains no more than 500 features.
Has anyone else experienced this issue?
