I'm being forced to recreate an app built in Web AppBuilder in Experience builder, but I've hit a snag. When I run a query (either spatial or data) I get the results in a filmstrip using the pop-up config settings, and the map zooms to the features, BUT it doesn't highlight them in any way, so it's impossible to know which are the relevant features. In WAB you could set the symbology, but this doesn't appear to be an option here. I'm sure there must be a setting somewhere that I'm missing, but it's not obvious.
I'm using Portal 10.9.1 which is set by my organisation.
I was able to get this to work, but the option to specify the symbology of the query results is on a different page.
Go to your query widget and click Action > Message action > Add a trigger > Records created > Map > Show on map. Then you can specify the symbology you are wanting for the results of your query. I attached some screenshots as well.
Have you played around with the actions? These are found in data and message actions and does work on my map.
Hi Laura,
Unfortunately, it makes no difference. I've tried the default yellow and also changed to blue, but nothing shows, unless I'm missing something.
Cheers
This is what I get when I query
As you can see, it has zoomed to 33795_006, but it's not highlighted in any way.
Hi Ryan,
Brilliant, thanks. 😀 Why does it have to be so complicated though?
I'm able to get this to work for three of the four layers in my query widget -- a pin is placed at the location of the query results so it is very clear. When I query the fourth layer, however, no pin is placed, and I cannot figure out what the difference in configuration is. Does anyone have any ideas as to whey 'Show on map' isn't working for one point feature class? Thanks in advance!
In case this is helpful to anyone, I resolved my issue described above. The layer for which no pin was being placed in response to a "show on map" message action in my query widget was a multipoint layer. Once I converted this from a multipoint layer to a point layer, a pin was dropped at the location of the result I selected from my query widget. Apparently multipoint layers are not supported. May this save someone some time...
