Group sharing not listing any existing groups - ArcGIS Enterprise 11.1
294
6
04-05-2024 08:33 AM
Thomas_Puthusserry
After a recent upgrade from 10.9 to 11.1, there is a situation where an item cannot be shared to groups: no groups are listed.
Just says: (see attached image)
0 - NaN of 0 groups
portal Index shows all groups.
However all groups are available. The groups are listed when a site hub is shared.
Any suggestions what is wrong?
PeijunCai
Hi Thomas,
Do you see the groups in the portal sharing REST API under user groups? The Portal Sharing REST URL usually is https://FQDN/portal/sharing/rest. When you log in as an admin, do you see the groups there?
A_Wyn_Jones
Hi @Thomas_Puthusserry,
There is a patch for this at 11.1 - https://support.esri.com/en-us/patches-updates/2023/portal-for-arcgis-11-1-sharing-patch
The recently released security patch also covers some fixes made by the aforementioned patch:
https://support.esri.com/en-us/patches-updates/2023/portal-for-arcgis-security-2024-update-1-patch
Essentially, please make sure your deployment is fully patched by using the "Check For Enterprise updates" tool on the machine.
Hope this helps,
A
"We've boosted the Anti-Mass Spectrometer to 105 percent. Bit of a gamble, but we need the extra resolution."
Thomas_Puthusserry
Hi @A_Wyn_Jones we haven't installed any patches yet: I see 4 patches available for portal 11.1
We have a HA deployment with 2 portal VMs and got couple of questions:
1. What is the order of the patch installation?
2. Do I need to install all patches listed below?
2. Do I need the validation and repair tool run first?
3. If Security 2024 update 1 patch is applied, then is it necessary to apply Sharing Patch (as it is also included in the security 2024 patch)?
Many thanks Thomas
A_Wyn_Jones
The order of patch installation is done for you via the "Install All Patches" button.
You need to run the validation and repair tool first before clicking Install All Patches
The sharing patch will be installed before the Security 2024 patch
You can automate this patching using the command line tools provided by Server, Portal or Datastore:
https://enterprise.arcgis.com/en/server/latest/install/windows/check-for-software-patches-and-update...
Keep in mind patching requires downtime of the component being patched.
Hope this helps!
Thomas_Puthusserry
Hi @A_Wyn_Jones Thanks for the tip. I have tried to recreate this in another instance which is upgraded to 11.1; however the issue with groups (BUG-000158232 - Members are not able to share items with groups through the ArcGIS Enterprise portal when owning or managing more than 29 groups configured to only allow owners and managers to contribute content) could not be reproduced. The idea was that, if I could reproduce this then apply the patches and then see whether that fixes the issue. As such I am not sure this bug is causing the issue I am facing.
Thomas
A_Wyn_Jones
Hi @Thomas_Puthusserry ,
Have you installed the latest Security patch on that instance too?
There's BUG-000158232 (again) and BUG-000164118 addressed in this patch:
If you have it all up to date - please raise with Esri tech support. Would be interesting to know if it's specifically your account!
A
