finding dependencies between Portal for ArcGIS 10.9.2 items in a folder
218
12-31-2024 09:44 AM
IreneEgbulefu1
Hello all,
I am working on Cleaning up some of the unused web maps, apps, and feature layers in my Portal for ArcGIS 10.9.2.
I tried using a script recommended on the Esri website, "
 Find dependencies in Portal for ArcGIS using ArcGIS API for Python [support.esri.com]."  unfortunately, the script listed all the dependencies on the entire Portal Site, in a very messy way that it was difficult to uniquely identify the files.
I tried to narrow it to the folder level by editing the script, but that didn't work. I tried to delete some of the web maps and apps manually, but I ended up deleting some of the critical files and having to rebuild the apps again.
I would really appreciate to get some help here
MichaelVolz
Esteemed Contributor
GeoJobe has a very powerful tool to perform this analysis (Admin Tools).  It has a cost associated with it, but I think it is worth it in terms of building code and working out the kinks in the code.
IreneEgbulefu1
This option wouldnt work for me because of the cost attached. I would be required to justify the cost  and this is not a justifiable because it is an Esri application and they expect that Esri should have a solution to the issue.
