I’ve attached a screenshot with several snippets for reference. I found a similar issue documented for AGOL (https://support.esri.com/en-us/knowledge-base/accessing-data-failed-000016280), but my data is referenced, and there are no <Null> values as indicated in the article.
Any assistance would be greatly appreciated.
Solved! Go to Solution.
Are you able to access your ArcGIS Server logs and see if there are any log messages regarding this issue? Also, it might be helpful to open your browser's dev tools, replicate the error, then see if there is any useful information in the internet traffic.
Thank you Ryan! I didn't notice there were spaces in a field name containing the word "of" (which is also a reserved word in ESRI products) within a view that I joined to in SQL.
I got this, headed out for the day now. Will revisit it tomorrow morning. Thanks for some direction Ryan!
