Create collaboration with ArcGIS Online "Collab_0065"
233
10-23-2021 06:49 AM
VictorTey
Hi, trying to set up collaboration between enterprise 10.9 to ArcGIS Online and coming across this error. The enterprise previous had domain https://gis.xxx.com and we changed it to https://gis.yyy.com/ . We updated all the urls used in the federation and items. Everything appears to work. However when I attempt to create this collaboration I get the error below. Any way we can fix this?
Edit: I got this error when trying to accept the response from arcgis online.
MehdiPira1
Hi @VictorTey
Try this one first:
My ArcGIS Online organization changed its URL key. How can I reestablish my organization as a collaboration participant?
You can accomplish this in one of two ways:
  • The collaboration host can delete and re-create a collaboration with the new URL key.
  • The collaboration guest may leave the collaboration and request to be reinvited by the host using the new URL.
https://enterprise.arcgis.com/en/portal/latest/administer/windows/common-questions-for-distributed-c...
if the issue persists, then try establishing a new distributed collaboration from AGOL to Portal.
Cheers
Mehdi
vtey_esriau
Thanks @MehdiPira1  for your reply. Unfortunately this is a fresh collaboration, configured from scratch. I have removed all previous collaboration configuration.
