Trying to add members from Active Directory. The search does not return the objects tag as Distribution Lists.
i.e. ...,OU=Distribution Lists,OU=Groups...
It does see the object if OU=Security Groups,OU=Groups
Is there a way to get Distribution lists included?
If you are using Azure AD (Entra) via SAML, this will be a setting in the application registration item in Azure. You, or your Azure admin, can choose what to send in the SAML assertion, which will include group membership information. I think it defaults to just security groups but you can tell it to include distribution groups too.
SAML is not an option and this is Windows AD, not azure
