Access Web Maps and Web Scenes hosted on the Portal from the backend
536
11-23-2021 01:42 AM
Labels (3)
FUngerStrabag
Hi folks,
We are looking for a way on how to access hosted web scenes and web maps (no feature, scene or map services - just the scenes and maps!) on the Portal - but from the backend!
Our goal is to create and access these programmatically in order to add (already hosted) content to them - e.g.
1. Creating a web scene
2. Adding content to it (simple building footprints hosted as a feature service)
3. Extruding it / assigning a color to it
The plan is that such a web scene gets automatically created whenever a project extent is defined (e.g. a button click after having a bounding box defined)
However, I could not find anything on the backend that is related to a mere web scene/web map.
Have you any experience of how to do this?
Many thanks!
Ferid
David_Brooks
MVP Regular Contributor
@FUngerStrabag AGOL Assistant is great for configuring the JS on hosted layers in both AGOL and Portal. It's a web app you just log into through your browser. https://ago-assistant.esri.com/
David
..Maps with no limits..
FUngerStrabag
Really cool! Thanks for that!
Is there a way to actually create e.g. a new scene or map and add data to them via the agol assistant programmatically? Should be, right?
David_Brooks
Should be manageable with python or portalpy maybe?
David
