When I load "https://<fqdn>/portal/home/organization.html", there are XHR requests to "https://<fqdn>/portal/sharing/proxy?https://local.portal/sharing/rest/search" with 500 HTTP Status code as responses.
My private Portal URL is "https://local.portal:7443/arcgis", not "https://local.portal".
I wonder where this parameter is set?
Thanks!
Hi nippo,
The privateportalURL is mainly used for communication between your federated Servers and Portal, so you wouldn't be seeing privateportalURL requests unless you were looking at traffic between your Server and Portal.
Thanks for your answer! I changed the way I path through "The username you entered is not a member of this organization." : https://community.esri.com/t5/arcgis-enterprise-portal-questions/linux-upgrade-10-7-1-to-10-9-1-quot...
I continue my staging process but I did not have anymore 500 XHR on https://<fqdn>/portal/home/organization.html
