ArcGIS Enterprise Questions
199
22.9M
7.6K
POST | When I go here: https://developers.arcgis.com/enterprise-sdk/api-reference/net/I see docs for 11.0, but no links for ... by KirkKuykendall1 Occasional Contributor III 0 2 | 0 | 2 | 49 | |
POST | Hi,I am trying to get user groups in SOI in Arcgis server 10.9.1HashSet<String> userRoleSet = ServerUtilities.GetGrou... by Dvirusb New Contributor III 0 0 | 0 | 0 | 57 | |
POST | Hello,I am using Server Object Extensions to add additional processing to ArcGIS REST services on operations like upd... by VincentLantaca New Contributor III 0 0 | 0 | 0 | 99 | |
POST | Hi,I've found what i think is a bug in the SOE devolped in arcgis enterprise SDK for JAVA.I have a IFeature Object ca... by pspada_WT New Contributor III 0 1 | 0 | 1 | 178 | |
POST | When I build SOE (or SOI) with old ArcMap ArcObjects I could use all the GP tool.I used the Geoprocessor library and ... by mody_buchbinder Occasional Contributor 0 3 | 0 | 3 | 256 | |
POST | Hi, I'm adding a newFeature to a Utility Network using a SOE.The problem is that when i add a new Feature it is all w... by pspada_WT New Contributor III 0 1 | 0 | 1 | 224 | |
POST | Hi, I've build a SOE that receive some object ID and delete that rows. It has work until I enable the branch versioni... by pspada_WT New Contributor III 0 1 | 0 | 1 | 221 | |
POST | Hi,I'm starting to develop a SOE that take this JSON{<!-- --> "INSERT":[ {<!-- --> "url":"C:\\Users\\pasq4\\Documents\\... by pspada_WT New Contributor III 0 1 | 0 | 1 | 233 | |
POST | Hi,In our organization, we have developed a utility using ArcGIS API for python in which we are capturing users prope... by AYUSHYADAV New Contributor III 0 1 | 0 | 1 | 449 | |
POST | Dear Community,I hope all of you are doing well,I have started to learn about SOE and SOI, I followed all the steps o... by Amir-Sarrafzadeh-Arasi New Contributor II 0 2 | 0 | 2 | 807 |
