ArcGIS Earth Blog
84
66.2K
36
Under Consideration | Good day:Here is my idea: Please add snapping functionality to ArcGIS Earth. This should be a basic requirement when ... by BryanAustin New Contributor II 2 2 | 2 | 2 | |
Under Consideration | It would be helpful to be able to import GeoPDFs without having to convert them to another format.Often we receive Ge... by SarahWillett New Contributor III 0 1 | 0 | 1 | |
Under Consideration | In ArcGIS Pro, the project name and the map name are shown in the header :It could be useful to do the same in ArcGIS... by GeoffroyRicher-Lalonde Occasional Contributor II 0 1 | 0 | 1 | |
Under Consideration | This is regarding an issue we have with the ArcGIS Earth app for Android. We are trying to use a local SLPK mesh file... by cbp-geus Occasional Contributor II 0 3 | 0 | 3 | |
Under Consideration | It would be great if there was a legend in ArcGIS Earth mobile. On my Android device, and confirmed with tech support... by RichOchs New Contributor III 1 1 | 1 | 1 | |
Under Consideration | The same as ArcGIS Pro on a windows machine can connect to a GPS and show location and log tracks, add the same suppo... by yigalm New Contributor III 4 2 | 4 | 2 | |
Under Consideration | The user can choose to use different Location Units :But the user cannot choose to use the negative symbol for South ... by GeoffroyRicher-Lalonde Occasional Contributor II 0 1 | 0 | 1 | |
Under Consideration | ArcGIS Earth 1.17 introduces a nice map layout exportation functionality. But it would be even better if the user cou... by GeoffroyRicher-Lalonde Occasional Contributor II 0 2 | 0 | 2 | |
Under Consideration | when zooming/panning to an object by double clicking on it in the table of contents, the map tilts in addition to zoo... by JeremiahPoling New Contributor II 2 5 | 2 | 5 | |
Under Consideration | When a user wants to continue a drawing (line or polygon), he can do so by clicking on the Continue Sketch button. Wh... by GeoffroyRicher-Lalonde Occasional Contributor II 0 3 | 0 | 3 | |
Under Consideration | When an element is selected in the TOC, it is highlighted on the globe. It would be useful to have the same link in s... by GeoffroyRicher-Lalonde Occasional Contributor II 1 3 | 1 | 3 | |
Under Consideration | There is an Elevation Exaggeration notice in the Elevation Profile tool :There is an Elevation Exaggeration notice in... by GeoffroyRicher-Lalonde Occasional Contributor II 1 6 | 1 | 6 |
Idea Submission Guidelines
