For iOS
Feature | Description |
Add data
| 1. Fixed a bug that scene service with multiple layers can not display. |
2. Fixed an issue that point cloud scene service could be loaded to ArcGIS Earth for iOS but failed to display. | |
Portal content
| 3. Fixed a bug that entering multi-word queries in portal content fails to load data in the living atlas. |
4. Fixed a bug that loading more view still animating when switching the tabs in portal content. | |
MSPK | 5. Fixed an issue that can’t switch to basemap from the mobile scene package (MSPK). |
Tour
| 6. Adjusted the size of photos displayed on a tour. |
7. Fixed a bug that tours screen recording failed constantly once crashed. | |
8. Deleted plus icon in front of the first photo in the tour editing page and disabled the photo panel scaled. | |
Measure
| 9. Changed default heading parameter of viewshed to match the camera heading and changed default unit to meters in Measure. |
Pop up | 10. Added a reminder of whether open in external browser when tapping a link in KML/KMZ pop up. |
UI
| 11.”-0” and “-0.00” will no longer display in Measure a point and Start status. |
12. Enhanced UI of viewshed that there is no ellipsis displayed in the Distance toolbar after selecting meters as the distance unit. | |
SDK | 13. Updated SDK from UIWebview to WKWebView for iOS 13 |
For Android
Add data
| 1. Fixed an issue that adding a layer with a graphic to the scene, changed the viewpoint to the layer and then the graphic flashed, even couldn’t be seen. |
2. Kept the visibility status of layers in layer list. | |
3. Updated icon for different data types displayed in the layer list. | |
Portal content
| 4. Fixed a bug when there was no more data to load in portal content, there was no reminder. |
5. Modified sort content of different groups to match the portal version. | |
MSPK | 6. Added the error message when loading the mobile scene package (MSPK) with unsupported spatial references. |
Tour
| 7. Fixed an issue that unable to add the pictures captured on Created Tour from Album dialog with the error message "Pictures without location information can't display" displaying. |
Measure | 8. Changed default heading parameter of viewshed to match the camera heading and changed default unit to meters in Measure. |
UI | 9. ”-0” will no longer display in Measure a point and Start status. |
Add placemarks | 10. Fixed an issue that My Placemarks pane displayed abnormally after deleting a placemark. |
11. Fixed a bug that only the most recently placed point could be renamed and had its color changed. | |
12. Supported to place placemarks on Android (6.x &7.x) devices. | |
My Location | 13. Fixed a bug that ArcGIS Earth for Android crashed after tapping the My location icon on Android (6.x) devices. |
Portal | 14. Fixed a bug that portal connection caused a crash. |
