Elevation profile in D2M 1.1
520
02-16-2017 10:21 PM
MikiHASHIMOTO
When I clicked [Elevation Profile] button, the following error message displayed.
「ArcGIS Pro 1.3 or greater with 3D Analyst extension must be installed and licensed for calculate elevation profile.」
ArcGIS Pro 1.3 is installed in the same machine.
What would you suggest I do?
LarsElmkær_Chwastek
Hi Miki,
First of all you should make sure that you have the 3D Analyst extension assigned to you in your ArcGIS Online Organization. If you have, then open ArcGIS Pro first and then Drone2Map. Then it should work, at least it did for me.
It seems that Drone2Map just have to realize that the extension is "turned on", by opening ArcGIS Pro :)
MikiHASHIMOTO
Hi Lars,
Thank you for your advice.
I could open Elevation Profile panel after I opened ArcGIS Pro.
Is the Calculate Volume tool of Measure same, too?
LarsElmkær_Chwastek
Hi Miki,
Great that the Elevation works now.
With regards to the Calculate Volume measure - this requires that you have build a Point cloud during the processing and again the 3D Analyst extension :)
