The error management and reporting may not be being used because they rely on rules being applied to individual feature layers/sub types.
Users have existing complex databases and could previously run batch files across the entire database. Rules require every feature to be updated.
Although this should only need to be completed once it is an overwhelming, time consuming and expensive task to undertake, especially when it needs to be completed on an extensive database that needs to meet a certain specification.
Some users are also overwhelmed by differences between desktop and pro versions that they are seeking out familiarity rather than learning new methods
