We have a FME workspace where I need to update rows in the table that meet a where condition. The condition is a string value. When I set up the sql statement it is like this.
UPDATE ADDRESSES.dbo.ADDRESSES_TEST set internalonly = 1 where 'PARCELID' = @Value(PARCEL_NUMBER)
and when the executor is run, the below error is returned for each feature.
Query failed, possibly due to a malformed statement. Query Text UPDATE ADDRESSES.dbo.ADDRESSES_TEST set internalonly = 1 where 'PARCELID' = 342073103690008 Provider error `(-2147217913) Error converting data type varchar to numeric.'
The PARCEL_NUMBER and the PARCELID fields are TEXT in both instances. This is what was used in python.
UPDATE ADDRESSES_TEST SET internalonly = 1 WHERE PARCELID = '{}'
where the PARCEL_NUMBER is quoted. Also, internalonly is a smallint in both databases
Any leads would be greatly appreciated.
use SQL Server function CAST or CONVERT
https://learn.microsoft.com/en-us/sql/t-sql/functions/cast-and-convert-transact-sql?view=sql-server-...
Michael the single quotes around PARCELID make it a literal and not an identifier. Just remove them.
Thanks for the quick reply.
Both statements with, and without the single quote return the same error.
Microsoft SQL Server Non-Spatial Reader: Query failed, possibly due to a malformed statement. Query Text `UPDATE ADDRESSES.dbo.ADDRESSES_TEST set internalonly = 1 where 'PARCELID' = 340750300650005'. Provider error `(-2147217913) Error converting data type varchar to numeric.'
and
UPDATE ADDRESSES.dbo.ADDRESSES_TEST set internalonly = 1 where PARCELID = @Value(PARCEL_NUMBER)
Microsoft SQL Server Non-Spatial Reader: Query failed, possibly due to a malformed statement. Query Text `UPDATE ADDRESSES.dbo.ADDRESSES_TEST set internalonly = 1 where PARCELID = 342073108650005'. Provider error `(-2147217913) Error converting data type nvarchar to numeric.'
The parcel number is a text string and should have quotes. This works with python and in SQL.
update ADDRESSES_TEST set internalonly = 1 where PARCELID = '342073103690008'
if i take the quotes away from the PARCELID and run in SQL, the same conversion error is given
Very much appreciate your help.
Thank you. That did the trick
UPDATE ADDRESSES.dbo.ADDRESSES_TEST set internalonly = 1 where PARCELID = CAST(@Value(PARCEL_NUMBER) As nvarchar)
Glad to help.
