list advance formatting based on value from another layer
212
05-10-2024 05:47 AM
DionysiosKerasidis1
Hi Community
May i please ask for a suggestion/advice. i am trying to create a list with advanced formatting which will read 2 layers and colour code the records based on if a record from one table found in the other one.
In other words, i have created a field app which captures data on site and i have a lookup table, need to compare if an ID is found from the lookup table and colour it green as an example.
jcarlson
The Arcade profile for advanced formatting in a list is limited to only looking at a single feature's attributes at a time.
The only way to join data from separate layers like that is to use a Data Expression.
- Josh Carlson
Kendall County GIS
jcarlson
- Josh Carlson
Kendall County GIS
DionysiosKerasidis1
Thanks Josh
i was expecting that would be the case.
