Dashboard/Indicator and Arcade
205
01-19-2022 09:13 AM
AnnettePoole1
Background - using Dashboard and the indicator widget.  When the widget has no data, the return is no data. Instead I would like to return a zero, "0".  Now with Arcade ability, I thought I might be able to do this, but need your help.  Here is what I have tried.
Using the below, I get "Unexpected Token If".  I wonder if this is because "If" is not listed in the function list.
return {
//textColor:'',
//backgroundColor:'',
topText: If ($datapoint["sum_number_of_citations_issued"] > '0'){
return '$datapoint["sum_number_of_citations_issued"]';
} else if ($datapoint["sum_number_of_citations_issued"] < '0'){
return '0';
topTextColor: '#ffffff',
topTextOutlineColor: '',
topTextMaxSize: 'medium',
//middleText: '',
//middleTextColor: '',
//middleTextOutlineColor: '',
//middleTextMaxSize: 'large',
//bottomText: '',
//bottomTextColor: '',
//bottomTextOutlineColor: '',
//bottomTextMaxSize: 'medium',
//iconName:'',
//iconAlign:'left',
//iconColor:'',
//iconOutlineColor:'',
//noValue:false,
//attributes: {
//attribute1: '',
// attribute2: ''
I also tried:
IIf($datapoint["sum_number_of_citations_issued"] < 1, '0')
and the error I get is Syntax Error: Function signature does not match; IIF
Thank you,
Annette
JayantaPoddar
Just try
For No Data value, just change the Default Label to 0.
Think Location
JayantaPoddar
Check if the following expression works.
var s = $datapoint["sum_number_of_citations_issued"]
IIF(s < 1, 0, s)
Think Location
AnnettePoole1
States unexpected token var.  Am I putting it in the wrong place. This is the indicator widget on dashboard.  I then removed it and placed the two lines at the top, but I wasn't sure what to put after topText: .
Thank you for your help.
return {
//textColor:'',
topText: var s = $datapoint["sum_number_of_citations_issued"]
IIF(s < 1, 0, s)
//middleText: '',
//bottomText: '',
//iconName:'',
//iconAlign:'left',
//iconColor:'',
//noValue:false,
//attributes: {
// attribute1: '',
// attribute2: ''
JayantaPoddar
Just try
Think Location
AnnettePoole1
Thank you so much! Is this a new feature with 10.9.1 or have I been blind! So easy. I knew it had to be. Thank you, thank you!
