Calculating changes in a feature over different dates
515
12-05-2022 11:31 PM
by Anonymous User
Not applicable
So this is potentially not possible to do with a data expression but I really do not know as this seems to be quite a complex calculation.
Consider the following table of daily sandbag counts. We are trying to dynamically count the Sandbags Taken figure based on data collected using a Survey123 count. There are 5 depots. I have been able to create a data expression that reports the latest count by depot and can use the Sum statistic on a gauge indicator to get the total current count. I am assuming that if I had the Sandbags Taken figure for each depot, I could do the same and get the grand total.
This next bit requires calculating totals for the last two dates (counts are not always daily and could be weeks apart hence needing Max(Date) and Max(Date)-1 or similar) and subtracting the total counts to calculate how many have been taken. For a bonus bit of difficulty, ideally we include the daily production figure (but currently this is in a different dataset to add a bit of complexity).
I would appreciate any thoughts on this, table below for (hopefully) some clarity.
The other alternative approach could be with Python to populate fields in the feature layer itself if a Data Expression is not going to cut it.
thanks in advance,
Len
DateOfCount
Depot
Count
Taken (calculated)
Produced
1/11/2022
A
100
2/11/2022
A
50
50 (count Date1 – countDate2)
150
3/11/2022
A
150
50 (CountDate2+ProductionDate1-CountDate3)
B
B
B
JohannesLindner
MVP Frequent Contributor
It is absolutely possible.
I changed your example table to reflect that the counts are not taken daily. I used the same values for depots A and B:
For the production, I just assumed that depot A fills 10 sandbags per day, while depot B manages to fill 20.
// load the count fs
var count_fs = Featureset(Text({
    fields: [
        {name: "DateOfCount", type: "esriFieldTypeDate"},
        {name: "Depot", type: "esriFieldTypeString"},
        {name: "Count", type: "esriFieldTypeInteger"},
    features: [
        {attributes: {DateOfCount: Number(Date(2022,11,1)), Depot: "A", Count: 100}},
        {attributes: {DateOfCount: Number(Date(2022,11,6)), Depot: "A", Count: 50}},
        {attributes: {DateOfCount: Number(Date(2022,11,22)), Depot: "A", Count: 150}},
        {attributes: {DateOfCount: Number(Date(2022,11,1)), Depot: "B", Count: 100}},
        {attributes: {DateOfCount: Number(Date(2022,11,6)), Depot: "B", Count: 50}},
        {attributes: {DateOfCount: Number(Date(2022,11,22)), Depot: "B", Count: 150}},
    geometryType: ""
//return count_fs
// load the production fs
var production_fs = {
    fields: [
        {name: "DateOfProduction", type: "esriFieldTypeDate"},
    features: [],
    geometryType: ""
for(var i = 0; i < 30; i++) {
    Push(production_fs.features, {attributes: {DateOfProduction: Number(DateAdd(Date(2022,11,1), i, "days")), Depot: "A", Count: 10}})
    Push(production_fs.features, {attributes: {DateOfProduction: Number(DateAdd(Date(2022,11,1), i, "days")), Depot: "B", Count: 20}})
production_fs = Featureset(Text(production_fs))
//return production_fs
// create the output dict
var out = {
    fields: [
        {name: "Taken", type: "esriFieldTypeInteger"},
        {name: "Produced", type: "esriFieldTypeInteger"},
    features: [],
    geometryType: ""
// loop over depots
var depots = ["A", "B"]
for(var d in depots) {
    // find all counts of the depot and order by date
    var depot = depots[d]
    var depot_count_fs = Filter(count_fs, "Depot = @depot")
    depot_count_fs = OrderBy(depot_count_fs, "DateOfCount")
    // loop over depot_count_fs
    var previous_depot_count = First(depot_count_fs)
    for(var depot_count in depot_count_fs) {
        // find all entries in the production_fs between now and the previous count date
        var start_date = previous_depot_count.DateOfCount
        var end_date = depot_count.DateOfCount
        var production_between_dates = Filter(production_fs, "Depot = @depot AND DateOfProduction > @start_date AND DateOfProduction <= @end_date")
        // calculate the values
        var current_count = depot_count.Count
        var produced = Sum(production_between_dates, "Count")
        var taken = previous_depot_count.Count + produced - current_count
        // append new feature
        Push(out.features, {attributes: {DateOfCount: Number(depot_count.DateOfCount), Depot: depot, Count: current_count, Taken: taken, Produced: produced}})
        // set previous
        previous_depot_count = depot_count
return Featureset(Text(out))
The "Taken" and "Produced" columns list the sandbags that were taken and produced between the current and the previous count.
Lines 1-35 define the sample data. They should of course be replaced with code loading your actual data sets.
Depending on your database and date format, you might have to change the sql clause in line 64.
Have a great day!
Johannes
JohannesLindner
    fields: [
    features: [
    geometryType: ""
//return count_fs
    fields: [
    features: [],
    geometryType: ""
var out = {
    fields: [
    features: [],
    geometryType: ""
// loop over depots
        // set previous
Have a great day!
Johannes
by Anonymous User
Not applicable
Hi @JohannesLindner I think you may be right that there could be a date issue in line 63 as my datecount_ field has both time and date and there could be more than one count a day (as I discovered) and I think there is an issue with some date expressions if the hours and minutes is Not Null.  I get a message Execution Error:Invalid data type for expression [date '2022-09-15 14:56:00']
Ironically this is not the first record in the table. Is there an issue if there is no previous count?
Does 'Between Date1 and Date2' work from an SQL point of view?
Substituting my real fieldnames into the expression,
var portal = Portal('https://XXXXX/portal/');
var count_fs = FeatureSetByPortalItem(
portal,
'YYYYYYYYYYYYYYY',
0,
'datetime_count',
'field_11',
'sandbag_outside',
'sandbag_insde',
'total_note',
false
//return count_fs
var production_fs = FeatureSetByPortalItem(
portal,
'ZZZZZZZZZZZZ',
0,
'datetime_',
'depot_',
'produced_sandbag',
false
var out = {
fields: [
features: [],
geometryType: ""
// loop over depots
var depots = ["DARRA", "LOTA", "MORNINGSIDE", "NEWMARKET", "ZILLMERE"]
var depot_count_fs = Filter(count_fs, "field_11 = @depot")
depot_count_fs = OrderBy(depot_count_fs, "datetime_count")
var start_date = previous_depot_count.datetime_count
var end_date = depot_count.datetime_count
var production_between_dates = Filter(production_fs, "depot_ = @depot AND datetime_ > @start_date AND datetime_ <= @end_date")
var current_count = depot_count.total_note
var produced = Sum(production_between_dates, "produced_sandbag")
var taken = previous_depot_count.total_note + produced - current_count
Push(out.features, {attributes: {DateOfCount: Number(depot_count.datetime_count), Depot: field_11, Count: current_count, Taken: taken, Produced: produced}})
// set previous
Thanks again, I feel that I am nearly there after a week of trying.
JohannesLindner
BETWEEN does work, but it includes both the start and end date, so the production values from days where you have a depot count are counted twice: once for the current count feature and once for the next. At least that's with only date values...
No, but it is the first record that gets processed, because DARRA is the first depot.
There shouldn't be problems if there is no previous count, if there are multiple counts on the same day, or if there is time involved. I didn't mean to prove against those cases, but apparently I did...
I think Arcade doesn't like the SQL query. You will probably have to write it yourself, without using the @ notation.
One of these might work:
// Define the sql query (using one of the methods below)
// use string
var df = "Y-MM-DD HH:mm:ss"
var sql_query = `depot_ = '${depot}' AND datetime_ > '${Text(start_date, df)}' AND datetime_ <= '${Text(end_date, df)}'`
// convert to sql DATE
var sql_query = `depot_ = '${depot}' AND datetime_ > date '${Text(start_date, df)}' AND datetime_ <= date '${Text(end_date, df)}'`
// switch to full days, this might lead to small errors, like production only being applied to the next period
var df = "Y-MM-DD"
// use it
var production_between_dates = Filter(production_fs, sql_query)
If none of these work, I'd need access to the actual data to help further. Either send a public link to the service or send me the tables in a pm.
Have a great day!
Johannes
by Anonymous User
Not applicable
Thanks so much for all your invaluable advice. I will give it a go and let you know how I get on.
