Arcade - How to use a date field with a dictionary ?
477
7
08-02-2021 09:06 PM
explocarto
With the Arcade language, I try to feed a dictionary with several fields of which one field is of type date.
This dictionary is fed from a feature service.
Here is an example of my code:
If I return the contents of my dictionary, I can see the date value.
But if I try to flip it this way:
return FeatureSet(Text(table_Dict))
Date values not appearing !
Can someone help me with this?
DavidPike
MVP Frequent Contributor
DavidPike
Peter_Klingman
Thanks @DavidPike - I have seen this come up a lot recently with increased adoption of Data Expressions. I'm thinking I'll submit an issue to see if a date field can be included in the FeatureSet example in the Arcade documentation.
DavidPike
I think that would be really helpful.
MICHAELOBIDA
PLS I NEEED ENVI 5.6 SERVER LINK
explocarto
Thank you both. :grinning_face:
Have a nice day
MICHAELOBIDA
Hello pls i need a line to download and  install this on my pc ARCGIS DESKTOP
JayantaPoddar
@MICHAELOBIDA : I would suggest you to write a new question, rather than commenting in replies to unrelated threads.
For instructions, please check How to ask a question - Esri Community
Think Location
