Using Premodeled buildings instead of the procedural generated ones
566
12-03-2023 02:48 PM
mohamadhani
New Contributor II
So i have about 30 Buildings that i 3d modeled, they are seperated as Huge,Big,Medium and small, so all the huge onces have the same Rectanglar base width and lengh , so are the other ones, my question is how can i use my 3d models instead of genereating buildings proceduraly and how can i use those buildings base width and lengh to make city engine knows where to put the huge,big,medium and small
Tags (3)
ThomasFuchs
Hello @mohamadhani
Thank you for your question. Procedural modeling with CityEngine allows you to use premodeled 3D buildings. To find the best fit for any given Parcel geometry, use assetBestSize function—ArcGIS CityEngine Resources | Documentation or one of the related asset utility functions.
mohamadhani
New Contributor II
Thank you for responce @ThomasFuchs , But as you can see we would need some randomization can you tell me how can we do that ?
ThomasFuchs
For randomly picking a fitting asset, please use the assetApproxSize function with the parameter n>1
assetApproxSize function—ArcGIS CityEngine Resources | Documentation
mohamadhani
New Contributor II
@ThomasFuchs  is there any way what i can contact you ?
ThomasFuchs
Dear @mohamadhani ,
Thanks for utilizing the CityEngine community forum for support. The forum is indeed a valuable resource for sharing knowledge and experiences with other users and the product team.
However, I would like to recommend that you also consider using the official Esri support. This means they have in-depth knowledge and can provide you with accurate, detailed, and comprehensive solutions tailored to your specific needs.
You can access Esri's official support at Esri Support Services
Best regards, Thomas F
