How to use CGA to solve the question of sharing one UV for the whole wall texture
531
08-16-2022 10:59 PM
chezhaoli
New Contributor II
Hello everyone, I'm a newbie. When I used CGA to create a 3D model in city engine, I encountered a problem, how to make different textures on a wall share one UV. Looking forward to your reply.
Usually, a face has one UV map
But now I want to make them share one same UV.liike this
How to deal with it .I hope someone could give me some suggestions.Thanks
Houskan
Hi chezhaoli,
Working with UVs typically includes two parts:
  1. setupProjection() -> Defines the UV coordinate space
  2. projectUV() -> Applies the UV coordinates
Step 1 is typically done early, before the facade is split. This ensures a global UV coordinate space. Step 2 is then done within the rule where you want to apply your specific texture  (i.e., Windows, Walls, etc.)
To illustrate on a simple example:
FacadeTex-->
    setupProjection(0, scope.xy, '1, '1) // (1) define UV coordinate space over the whole facade
    Facade
Facade --> split(y) { floor_height : Floor }*
Floor --> split(x) { tile_width : Tile }*
Tile-->
   texture("my_texture_file.jpg")
   projectUV(0) // (2) Apply the UV coordinates
For more information about facade modeling and texturing check out Tutorial 7. I think the tutorial covers exactly what you are looking for.
Best,
Niklaus
Houskan
Hi chezhaoli,
FacadeTex-->
    Facade
Tile-->
Best,
Niklaus
chezhaoli
New Contributor II
Thanks for your help!I solved this problem~Sorry for taking so long to reply.
