Extruding polygons using attribute
256
05-31-2024 04:23 AM
aogino
What is the right .cga rule to apply to a shapefile in order to extrude the polygons in it to a height using an attribute of the shapefile ?
Currently using this one that I found on the net :
version "2023.1"
attr hauteur = 10 // Default value in case the attribute is missing
Lot -->
extrude(hauteur) // Extrude the shape to the height specified by the "hauteur" attribute
@StartRule
Building --> Lot
But it isn't working. Any kind of help would be appreciated !
ThomasFuchs
Hello @aogino
Your CGA code compiles without error. When applying it to a shape, the resulting model is the shape extruded by 10m.
