Hi, I suggest that when an attribute contains several options, when we select an item, only the attributes related to this option are activated at the bottom for control, and also when we select the second option, the attributes related to this option only Appear and hide the rest and ... This way inspector does not get crowded.For example, when we select the Form1 option, only the attributes related to this item will appear and the rest will be hidden. as well as for the other options.
Thank you for your input!
