Time aware infographic
528
11-27-2019 09:04 AM
Status: Under Consideration
JennyKuan
New Contributor III
It would be great if infographics could incorporate some elements of the "time slider" widget, where the data shown on the infographic would appear progressively with the time. What would be even greater would be to have the infographic work simultaneously with the time slider widget, so that the elements appearing on the map would coincide with the data on the infographic. So far, I have not been able to tweak the infographic widget to do any of this and I have no idea whether it is possible to do this on BAO.
The only Web Mapping Application that I have seen do this successfully is the "U.S. Precipitation Forecast" but there was a lot of coding involved to create such an application. Licenses are also required to try and replicate this it seems.
Thank you!
Jenny
1 Comment
HelenBrown
