MapTour Template - Story Map not loading
318
07-20-2021 06:29 AM
JoshuaBillings
New Contributor III
Hey all,
I am looking to use AppStudio to create a map tour similar to the Palm Spring tutorial (https://learn.arcgis.com/en/projects/use-arcgis-appstudio-to-build-a-map-tour/).
When I put in the map tour id (for the StoryMap that I created) into the Properties section of AppStudio and then run the app, the story map doesn't appear and I get a message that says "No Maps to Display."
Anyone have any suggestions? Thanks!
JoshuaBillings
New Contributor III
Hey Erwin,
I did end up finding the solution - I was just not putting the "id:" syntax in the query for the map tour. The tutorial didn't include it, so I didn't think I needed it.
Thanks for reaching out!
ErwinSoekianto
@JoshuaBillings
I am not aware of any issue similar to what you described. Can you share the MapTour id with us? or maybe work with Esri Technical Support?
Erwin.
JoshuaBillings
New Contributor III
Hey Erwin,
BenSiggery
New Contributor II
Hi there! Mine is doing exactly the same thing. Very new to appstudio so very likely me doing something wrong.
Test MapTour is: https://arcg.is/59n5S ID: 4e42e8aa8eb9424e8da2585e06da8bf5
Works fine when I use the Palm Spring example ID but not my own ID.
JoshuaBillings
New Contributor III
Ben, the tutorial doesn't instruct that the "id:" syntax must be included in the map tour query but it should. That's what was tripping me up.
Additionally, I wasn't able to see your Story Map (it's not shared publicly) so that may also be another issue. The Story Map must be shared publicly before you'll be able to see it in the app.
Hope this helps!
BenSiggery
New Contributor II
Aha! Working for me now too. Thanks Joshua!
