Error during cloud make for Android
767
11
07-06-2021 10:06 AM
RaufShaikh
Hello Friends,
I am building an App in AppStudio. I have generated the keystore file using the command: keytool -genkey -v -keystore [keystore_name].keystore -alias [alias_name] -keyalg RSA -keysize 2048 -validity 10000 as mentioned here https://doc.arcgis.com/en/appstudio/extend-apps/signyourapp.htm under section Sign your Android app .
Surprisingly, when I run the command it doesn't ask me to perform step 7, Enter a key password. This password can be unique, or press Enter to use the same password as the keystore password. Without asking me to enter Key password the Keystore file gets genearted with .keystore extension. I have linked this keystore file with my App by going to settings>platforms>Android , KeyStore file path.
Now, when I do cloud make we have to enter KeyStore and upload key passwords, here I enter the same password for both KeyStore and Upload key, which I have entered for my KeyStore file while generating it using the keytool. When I start the make processs, it gives me the below error
Any help on this is much appreciated.
Rauf
RaufShaikh
Hi Carlos/ Erwin,
Try adding flag -storetype jks to the keytool command  as below:
keytool -genkey -v -keystore {Name].keystore -alias [Alias] -storetype jks -keyalg RSA -keysize 2048 -validity 10000
Apparently in order to perform cloud/local make for android platform using AppStudio, the keystore file should have .jks extension or if you are following the AppStudio documentation  https://doc.arcgis.com/en/appstudio/extend-apps/signyourapp.htm then add flag -storetype jks to the keytool command mentioned in that article.
Once I generated Keystore file using the above mentioned keytool command, I was able to successfully perform the cloud make.
Esri team should update the link  https://doc.arcgis.com/en/appstudio/extend-apps/signyourapp.htm to include this information.
I hope this will help.
Rauf
ErwinSoekianto
Rauf,
It looks like there is an issue with the password, can you try changing the password to not use special characters?
Erwin.
Carlos_Carvalho
Hi Erwin,
I'm having the same issue. I changed the password for letters only but i get the same error.
Can you help?
Thanks.
RaufShaikh
Hi Carlos/ Erwin,
Rauf
RaufShaikh
Generating keystore using the below command should also work.
keytool -genkeypair -alias upload -keyalg RSA -keysize 2048 -validity 9125 -keystore keystore.jks
Carlos_Carvalho
Carlos_Carvalho
Thanks RaufShaikh, it worked.
Thanks for your advise, I appreciate it.
kind regards
RaufShaikh
Hi Carlos,
I am glad it helped. Could you please mark it as accepted solution?
Rauf
Carlos_Carvalho
No problem, how can I do it?
RaufShaikh
By clicking on the Accept as Solution button below my reply where I have provided the solution.
Rauf
