AppStudio App Debugging issue
1489
02-21-2018 01:52 AM
ManishSharma4
New Contributor II
Hi All,
I have followed all the steps as mentioned in Debugging JavaScript in Qt Creator—AppStudio for ArcGIS | ArcGIS  to debug the app studio app. Everything is fine but once i try to debug the app,it is not recognizing the framework and showing the below error -
Starting C:\Qt\Qt5.10.1\5.10.1\msvc2015_64\bin\qmlscene.exe...
file:///C:/Users/Rabi/ArcGIS/AppStudio/Apps/d0e72ccb693c4ba4a3dab25ee4818e4c/MyApp.qml:25 plugin cannot be loaded for module "ArcGIS.AppFramework": Cannot load library C:\Qt\Qt5.10.1\5.10.1\msvc2015_64\qml\ArcGIS\AppFramework\AppFrameworkPlugin.dll: The specified procedure could not be found.
C:/Qt/Qt5.10.1/5.10.1/msvc2015_64/bin/qmlscene.exe exited with code -1
If any idea or suggestions, please let me know.
Code is-
import QtQuick 2.6
import QtQuick.Controls 2.1
import QtQuick.Controls 1.4
import QtQuick.Layouts 1.1
import QtPositioning 5.3
import QtSensors 5.3
import ArcGIS.AppFramework 1.0
import ArcGIS.AppFramework.Controls 1.0
import Esri.ArcGISRuntime 100.1
App {
    width: 414
    height: 736
    property real scaleFactor: AppFramework.displayScaleFactor
    //header bar
    Rectangle {
        anchors {
            left: parent.left
            right: parent.right
            top: parent.top
        height: 50 * AppFramework.displayScaleFactor
        color: app.info.propertyValue("titleBackgroundColor", "purple")
        Text {
            anchors.centerIn: parent
            text: app.info.title
            color: app.info.propertyValue("titleTextColor", "white")
            font {
                pointSize: 18
            wrapMode: Text.WrapAtWordBoundaryOrAnywhere
            maximumLineCount: 2
            elide: Text.ElideRight
            horizontalAlignment: Text.AlignHCenter
    MapView {
        property real initialMapRotation: 0
        anchors {
            left: parent.left
            right: parent.right
            top: titleRect.bottom
            bottom: parent.bottom
        rotationByPinchingEnabled: true
        zoomByPinchingEnabled: true
        locationDisplay {
            positionSource: PositionSource {
        // add a basemap
        Map{
            //BasemapTopographic{}
            //BasemapStreets {}
            BasemapImagery {}
            initialViewpoint: ViewpointCenter {
                center: Point {
                    x: -11e6
                    y: 6e6
                    spatialReference: SpatialReference {wkid: 102100}
                targetScale: 9e7
        // map control buttons
        Column{
            spacing: 5 * scaleFactor
            anchors {
                verticalCenter: parent.verticalCenter
                right: parent.right
                margins: 5 * scaleFactor
            Button{
                Image{
                    source: "./images/home.png"
                    height: 40 * scaleFactor
                    width : height
                width : height
                onHoveredChanged: hovered ? homeButton.opacity = 1 : homeButton.opacity = .5;
                opacity: .5
                onClicked:{
                    mapView.setViewpointWithAnimationCurve(map.initialViewpoint, 1.0, Enums.AnimationCurveEaseInOutCubic)
                    mapView.setViewpointRotation(mapView.initialMapRotation)
            Button{
                Image{
                    source:"./images/location.png"
                    height: 30 * scaleFactor
                    width: height
                onHoveredChanged: hovered ? locationButton.opacity = 1 : locationButton.opacity = .5;
                width : height
                opacity: .5
                onClicked: {
                    if (!mapView.locationDisplay.started) {
                        mapView.locationDisplay.start()
                        mapView.locationDisplay.autoPanMode = Enums.LocationDisplayAutoPanModeRecenter
                    } else {
                        mapView.locationDisplay.stop()
SiddeshPillai1
Hi Manish,
I have few questions for you. This will help me to narrow down the issue that you experiencing.
1. Did you run the script located at C:\Users\Rabi\Applications\ArcGIS\AppStudio\sdk\ideintegration\post-install.bat before you opened the project on Qt Creator?
Try running on Admin mode
2. Can you confirm whether you have the correct setup in place by checking if all the files are present in the following the location?
3. Are you trying to run the project on debug or release mode?
We recommend using release mode.
Best,
Siddesh
ManishSharma4
New Contributor II
Siddesh Pillai wrote:
Hi Manish,
Best,
Siddesh
Hi Siddesh,
Thanks a lot for your revert. I am mentioning my comments as below-
1. Once i have run this script (C:\Users\Rabi\Applications\ArcGIS\AppStudio\sdk\ideintegration\post-install.bat)directly through command prompt then it did not copy ArcGIS and Esri Folder at path(C:\Qt\Qt5.10.1\5.10.1\msvc2015_64\qml\ArcGIS\) Then i have set directory path to batch file like-
and executed batch file again,Now files are appearing at the given path as-
neither app is working on debug mode nor in release mode it is showing error-
Please help.
Regards,
Manish Sharma
SiddeshPillai1
Hi Manish,
Thanks for working through the steps.
Based on your console log, it seems that the runtime module has not configured properly.
Can you try running the Advanced Configuration Tool located at C:\Users\<user>\Applications\ArcGIS\AppStudio\bin\AdvancedConfiguration.exe and provide the qmake path for msvc_2015 kit with C:\Qt\Qt5.9.1\5.9.1\msvc2015_64\bin\qmake.exe ? Give this a shot and let know if it still doesn't work.
Best,
Siddesh
ManishSharma4
New Contributor II
Hi Siddesh,
Thanks for your reply, i am adding few screen shots again as suggested.
Still it showing the below error-
Kindly check the same. Appreciate your efforts, please suggest.
Regards,
Manish Sharma
ShobanaSuresh
Hi Manish,
AppStudio 2.1(including AppFrameworkPlugin.dll) was built using Qt5.9.1. I think qmlscene.exe from Qt5.10.1 installation is not able to load the AppFrameworkPlugin.dll built with Qt5.9.1. This is most probably a Qt bug since the Qt Framework is supposed to be backward compatible.
It looks like you've already switched from using Qt5.10.1 to Qt5.9.1.
Can you check if Esri folder is present in C:\Qt\Qt5.9.1\5.9.1\msvc2015_64\qml? If not, running the post_install script again should resolve the error in the screenshot you've shared above.
Also copy the 2 Runtime dlls from UserHome\Applications\ArcGIS\AppStudio\sdk\windows\x64\lib to C:\Qt\Qt5.9.1\5.9.1\msvc2015_64\bin.
FYI. There's a known bug in AdvancedConfiguration tool. It does not copy the ESRI folder correctly to Qt install location.
cc: Siddesh Pillai
Thanks
Shobana
