Why is my definition query having no effect?
460
09-29-2022 11:04 PM
MichaelBell
I'm trying to narrow down a layer using the lyr.definitionQuery = ... method, as below:
result = arcpy.mp.ConvertWebMapToArcGISProject(data, templateFull)
aprx = result.ArcGISProject
#get the map, layer, apply the definition query
m = aprx.listMaps()[0]
lyr = m.listLayers("MyLayer")[0]
lyr.definitionQuery = "GUIDId = '" + RequestedGUIDId + "'"
Now, this works fine if I do it using my current project on my computer, with everything loaded locally (so I don't have to bother with the ConvertWebMapToArcGISProject). However, we're trying to implement this online, so we have to get a json containing the layers we need and convert it to a project in the code.
Now, for some reason, the lyr.definitionQuery line is not working - or more rather, it's having no effect. No matter what, it always returns the same number of features, which is odd (as my layer contains about 20,000 features - yet it always returns 151, even if I enter different values, or even values that don't exist!).
The layer does support definition queries (I've tested that), and it definitely recalls the definition query (I've given it a delay after the definition query is set, and checked it by outputting). It's getting set, but for some reason the layer isn't paying any attention to it.
Clubdebambos
If the goal here is to apply a filter to a layer in a webmap in ArcGIS Online use the following.
from arcgis import GIS
from arcgis.mapping import WebMap
## connect to AGOL
agol = GIS("home")
## get the WebMap you want to update
wm_item = agol.content.get("WEBMAP_ITEM_ID")
## create WebMap object
webmap = WebMap(wm_item)
## get the layer of interest
lyr = webmap.get_layer(title="LAYER_NAME")
## the query to apply
def_qry = "GUIDId = '{0}'".format(RequestedGUIDId)
## set the filter definition
lyr.layerDefinition.definitionExpression = def_qry
## update the webmap
wm.update()
~ learn.finaldraftmapping.com
MichaelBell
That's definitely some useful code. However, my code *was* working, but my code hadn't been put together well. I was trying to address a layer which didn't exist because I hadn't given it a title in the json I'm putting the webmap together with.
