Searching for Web Maps in Portal and querying if saved in Classic or New Map Viewer
252
04-14-2024 08:31 PM
Kalu_Ribush
Hello
When searching for web map in the Portal, for example using python below:
webmaps_contents = gis.content.search("*",item_type="Web Map", max_items=500)
Is it possible to filter for Web Maps saved in Classic or the New Map Viewer?
Or can this be done with with an if statement in a loop:
for webmap_item in webmaps_contents:
    if webmap_item. .....
2 Solutions
EarlMedina
I think one way you might be able to do this is:
for webmap in webmaps_contents :
    data = webmap.get_data()
    authoring_app = d["authoringApp"]
    if authoring_app  == "ArcGISMapViewer"
        # Created with new MapViewer
        pass
    else:
       # Classic webmap (authoring_app is "WebMapViewer")
       pass
At least, based on my observations the Authoring App value is "ArcGISMapViewer" for the new MapViewer and "WebMapViewer" for the classic MapViewer.
Kalu_Ribush
Thank you.  Worked with a  couple of tweaks:
    authoring_app = data["authoringApp"]
    if authoring_app  == "ArcGISMapViewer":
        pass
    else:
       pass
EarlMedina
        pass
    else:
       pass
Kalu_Ribush
        pass
    else:
       pass
